2G Any idea what this noise is, coming from dash?
PrimerPLus
1,160
20
Jul 28, 2011
Tokyo, Asia
I have had this noise for a while and I can not figure out what it is. Also I can only hear it at idle, from inside the car. If I go under the hood I can't hear it. Maybe its being drowned out I don't know. Maybe someone knows what this noise is.
It's most likely not it, but check your hood hinges. I was getting this annoying rattle that sounded like it was in the dashboard and I was not having any luck finding it. Eventually I found that it was the passenger side hood hinge.
Like compressor said check the dash. Something is loose. Check wiper motor assembly. Should start putting your hand inside the dash touching components noise goes out you found the culprit. Also check things that are bolted to the firewall from engine bay. Or might be something slightly touching hood. Bov or something like that.
