Dsm_Roly
- 225
- 0
- Nov 3, 2008
Regina,
SK, Canada
Okay, I've searched and searched and haven't found anyone with the same symptoms. So I've had a high idle ever since I put my new transmission in. I had problems before but not as bad as it was. Okay so I've had the idle for a while and since then I have replaced the IAC the TPS, the entire bottom half of the TB, and the Intake manifold. I'm still experiencing high idle, I personally think its the o'rings on the injectors, I have sprayed TB cleaner on them and the idle decreased almost instantly but not low enough. Other problems I have is my exhaust manifold starts smoking quite perfusely after getting hot from around the gasket, it has a smells but i don't think it's coolant unless the turbo blew? ... it might just be PB blaster but after I turned off the car I noticed the oil got too hot really fast. I took off the oil cap and it was like steamy or smokey? also i have "putting" in my exhaust at idle. I am low on coolant and have no fans on it right now so i don't let it sit on for too long or drive it around. Anything would be helpful.. thank you
