Aftermarket Head Gasket/Head Bolts/Head Studs Part Numbers Catalogs for DSM
DSMPT
DSM Wiseman
3,458
3,299
Jun 12, 2014
Japan / Mexico, Arizona
This post is for trying to make it easier to choose and order head gasket and head bolt/stud kit.
Head gaskets :
I excerpted only DSM section from manufacturer's catalogs. You can download it by clicking manufacturer's name below.
ARP off the shelf head bolt/stud kits :
Please refer the part numbers shown below to order. You can see each instruction that show recommended torque by clicking part number.
L19 head stud kits :
I linked the vendor's item page.
You can purchase most of those parts through supporting vendors in this forum. But not all vendors list all part numbers on their online store. If you don't find what you are looking for on their store, simply contact the vendor and tell the part number to order. Or you can PM me anytime. I can help you, too.
* If you are looking for rotating assemblies, please refer the link below.
Aftermarket Pistons/Rods/Crank/Bearings Part Numbers Catalogs for DSM :
https://www.dsmtuners.com/threads/aftermarket-pistons-rods-crank-bearings-part-numbers-for-dsm.533019/
I hope you find this post helpful.
* All files are listed in alphabetical order.
* I marked red the section that can be for DSM if the page has other car's part numbers.
* I selected the ones that probably you can easily order through most of parts stores or shops in North America. If I am missing something, please let me know.
Head Gasket
4G63 (6/7 Bolt)
- Cometic MLS Head Gasket 4G63
- Fel-Pro Composite and MLS Head Gasket 4G63
- HKS Stopper Type Metal Head Gasket 4G63
- SCE Copper Head Gasket 4G63 (Titan Copper/Pro Copper/ICS Titan)
* O-Ring/copper gasket installation instruction is included.
- Mitsubishi Composite Head Gasket 86.00mm Bore (Part # MD183808)
- Mitsubishi MLS Head Gasket 86.00mm Bore (Part # MD349347)
420A
- Cometic MLS 420A
- Fel-Pro MLS 420A
Note :
Cometic show bore diameters and only .051" thickness for 4G63 (.040" for 420A) in their catalog. But you can select a bore diameter and a thickness from the chart below and combine them to make a part number. Select your desired bore diameter and then put your desired thickness as last 3 digit after dash (-) on part number.
For instance, if you want a DSM 86.00mm bore/.060" thickness gasket, you can order it as C4234-060.
* The standard thickness of Cometic head gasket for early 4G63 that you normally find on most of store is .051".
* Price of Cometic head gasket is normally separated by 4 levels according to the thickness range below.
.027~.051, .056~.075, .080~.098 and .120.
* Both 4G63 and 420A Cometic head gasket up to .051" have 3 layers, and .056" or thicker have 5 layers.
4G63
Bore Diameter
85.50mm = C4233
86.00mm = C4234
87.00mm = C4235
Thickness
.027
.030
.036
.040
.045
.051
.056
.060
.066
.070
.075
.080
.084
.092
.095
.098
.120
420A
Bore Diameter
87.50mm = C5497
88.50mm = C5498
Thickness
.027
.030
.036
.040
.045
.051
.056
.060
.066
.070
.075
.098
.120
Head Stud/Bolt Kit
6 Bolt
- ARP 8740 Head Stud Kit 6 Bolt (Part # 207-4201)
- ARP 8740 Head Stud Kit Undercut 6 Bolt (Part # 207-4701)
- L19 Head Stud Kit 6 Bolt
Extreme PSI :
https://www.extremepsi.com/store/ARP-L19-Headstud-Kit-Mitsubishi-Eclipse-6-Bolt.html
7 Bolt
- ARP 8740 Head "Bolt" Kit Undercut 7 Bolt (Part # 207-3900)
- ARP 8740 Head Stud Kit 7 Bolt (Part # 207-4203)
- ARP 8740 Head Stud Kit Undercut 7 Bolt (Part # 207-4702)
- ARP Custom Age 625+ Head Stud Kit 7 Bolt (Part # 207-4302)
- L19 Head Stud Kit 7 Bolt
Extreme PSI :
https://www.extremepsi.com/store/ARP-L19-Head-Stud-Kit-Mitsubishi-Eclipse-7-Bolt.html
MA Performance :
https://www.maperformance.com/products/l19-head-stud-kit-by-arp-7-bolt-mitsubishi-dsm-evo-8-9
- 1/2" L19 Head Stud Kit
Boostin Performance
https://shop.boostinperformance.com/product-p/bp-demonkit-headstud.htm
420A
- ARP 8740 Head Stud Kit 420A (Part # 141-4202)
Note :
To install Boostin Performance 1/2" L19 stud kit on 6 Bolt block, you would need a 1/2-13" TIME-SERT thread repair kit in case if machinist doesn't have the right size tools. and Ten (10) 1/2-13 1.00" length inserts for a block. Also it requires to machine your cylinder head (Both 6/7 Bolt). TMZ Performance shouldered dowels for 1/2" studs are highly recommended, those are the right parts for this. And no more worries that you damage your cylinder head by torquing over 100 ft-lbs. (specific instructions for machinist come with the parts)
7 Bolt block, it doesn't require the Time-Sert inserts.
- TIME-SERT 1/2-13 Kit (Part # 0121)
- 1/2-13 1.00" Length Carbon Steel Inserts (Part # 01213)
- 1/2-13 1.00" Length Stainless Steel Inserts (Part # 01214)
http://www.timesert.com/html/inchsert.html
- Shouldered Dowels (Inserts) for Cylinder Head
TMZ Performance (@twicks69)
DSM/EVO Shouldered Dowels For Cylinder Head Reinforcement (11mm, 12mm, 1/2″)
https://www.tmzperformance.com/shop/tmz-performance-dsmevo-shouldered-dowels/
