1G Aftermarket Flywheel/ACT PP - Can I clean/reuse- would u?
pieceofcloth
Supporting Member
575
562
Oct 6, 2019
Houston, Texas
These came with my car that I recently picked up.The vehicle was flooded back in 2016 and hasn't been touched since. when I took transmission off, these things came with it. Could I use a brass wheel and clean the surface off the flywheel & reuse? How about the pressure plate, do you think I could get away or what can you guys, with experience, see could possibly go wrong? I would replace the disc tho. ::Can anyone recognize this flywheel?
Thank you all in advance :hellyeah:
Only thing I'd try reusing is the flywheel but from what I've read, it has to be stepped when resurfacing. I'd trash the pp and disc. You don't want any parts coming loose and/or come apart.
Right on bro:hellyeah: My uncle has a brake lathe, I'ma see if he can run it thru there. Thank you for your input/reply:hellyeah:
Yea that clutch disc is toast for sure. Trash it. The pressure plate is debatable, but for how cheap you can get a new one I'd just trash it too. New clutch and pressure plate for sure.
actually it looks like
it looks like one of those Fidanza Aluminum Flywheels. I was just on their site & they sell a friction plate kit for around 100. I'll just go and do that instead. Thanks again:hellyeah:
i was hoping to use reuse the pressure plate but your absolutely right. I don't think its worth the risk/future work. thanks bro:hellyeah:
Brake lathe isn’t recommended for flywheels if just using a simple steel bit.
What is recommended is a Blanchard grinder.
I’ve done both, but I’ve yet to have a car over 350whp.
I believe it’s not as big a deal with 4/6 puck style discs.
I was unaware of this early on messing with cars. Just passing on information that was passed on to me.
Also, correct. Seems like Fidanza flywheel or similar. Obviously reuse. Just check for cracks, chips, dents, etc. People drop sh**.
I’ve reused secondhand pressure plates and discs, but that’s poor practice and not recommended.
If I were in your shoes I would just buy a new clutch kit and reuse flywheel with a new surface.
Some Evaporust would take all of that rust off of those parts and show you better what you are working with, without removing any base metal and is non toxic.
You know I h
Check this out :
you can see each section has 2 cracks along but they don't slide thru the metal. Its more like some surace scratch/crack. I personally want to try to see if it'll still hold up, which I'm pretty sure it will but I would have to replace that disc & I don't want to buy the kit. I may just throw this up for sale.
I would throw that flywheel away, if that thing ever comes apart at high rpm it can kill you or bystanders or at the least it will destroy anything in its path including your block, transmission, turbo, firewall, radiator, hood, etc...I have seen it.
Yeah, I hear ya. I ain't trying to put anyone in that danger. I appreciate ya :hellyeah:
Get a new flywheel, media blast the pressure plate friction surface and replace the disk.
I had to edit my response because it looks like I can't even use this awd flywheel in my fwd. I'll still hold onto it & perhaps another awd will enter my life soon.. I appreciate all yalls input :hellyeah:
