Street Build Bleakley's 2G, working on 325whp
Ownership Status
Currently Own
Eagle Talon TSi
Turbo Type
16g
Drivetrain
FWD
Automatic
Build Type
  1. Street
Hot parts:
-FP manifold w/ TPP manifold blanket
-MHI EVO III 16G w/ PTP turbo blanket
-Standard MHI E316G hotside --> TD05H wheel, 7cm housing
-JMF external wastegate O2 housing, o2 dump
-Tial MVS wastegate, coolant fittings hooked up
-Apexi N1 downpipe
-Apexi N1 exhaust
Intake and charge parts:
-Apexi dual funnel filter
-stock MAFS
-Injen recirc'd intake pipe
-CX Racing same-side FMIC
-Tial QR BOV, recirculated
-stock Intake Manifold
Fuel mods:
-Walbro 255 LPH HP fuel pump on stock hanger
-8 gauge power and ground fuel pump rewire, 30A relay
-Stock 5/16" feed line
-Stock fuel filter
-Extreme PSI's "fuel feed" filter to rail upgrade kit --> -6AN SS line from filter to fuel rail
-AEM fuel rail
-Stock, cleaned, serviced, flowbenched 450cc injectors
-Aeromotive a1000 FPR
-stock 1/4" return line
Ignition:
-MSD spark plug wires
-Stock ignition setup
Electrical:
-1/0 gauge power and ground battery relocation setup
-Optima D34/78 in a Moroso battery box
-Galant 2.4 90A alternator (stock was 75)
-HELLA horn
-Viper 5305V 2-way security and remote start / keyless entry system
Mods-Engine
Stock bottom end
Bone stock head and intake
Mods-EMS & Logging
-Stock ECU (DSMLink coming soon...)
-Innovate LC-2, digital wideband AFR controller
Gauges:
-Innovate DB-Red, digital wideband AFR gauge
-Autometer Sport Comp, 30/30, mechanical Boost/Vacuum gauge
-Autometer Sport Comp, 0-100psi, electric fuel pressure gauge
-Autometer Sport Comp, 0-100psi, mechanical oil pressure gauge
-Autometer Sport Comp, 100-250°F, electric water temp. gauge
-Autometer Sport Comp, 100-250°F, electric transmission temp. gauge
-Autometer Sport Comp, 8-18V, short-sweep voltmeter
Mods-Drivetrain
F4A33:
-IPT valvebody
-IPT end clutch
B&M Racing trans cooler w/ fan. Part # 70298
-Forced Four SMART 100.1 shift box / TCU
Torque Solutions billet, polyurethane engine/trans mounts
Outlander front brakes upgrade
Early 2G AWD vented rear brakes upgrade
STM ABS delete kit
Stock suspension.
Stock wheels and tires.
Background
A little more out of that 16G sounds good to me.
Dyno Type
Mustang Dyno
Dyno Shop Name
CCAC
Dyno Session Details
Didn’t make it onto the dyno. Maybe one day...
Bleakley
More in 2G DSM
Share this Vehicle
