AEM White Wire Connection on 1G
bgold87
72
26
Nov 20, 2019
Louisville, Kentucky
I need to wire in my AEM Wideband, where to a run the white wire on a 1g? I found this pic on the vfaq that it's down on the passenger kick panel. All the other articles on it are missing pics.
Yea I saw that. Cant use pin 4 unless I’m simulating narrowband and using factory 02 which I’m not, put the sensor in the downpipe. According to ecmlink pin 15 doesn’t work with AEM and can’t use the others unless running speed density. So I’m curious what other have done.
Do you want to keep the factory O2 sensor or not? If you simulate the narrow band in ECMLink, you wouldn't need the factory O2 sensor anymore.
