Test Connection on my 1G Talon???
Cheks_Talon_TSi
228
3
Oct 24, 2003
Monterrey, N.L., Central America
Does someone knows what is this Test connection behind the intake manifold of my 1G Turbo Talon???
This test connection is in the fire wall... here I have some more pics... take a look!!
One more
Hope someone can give me any idea...
Thanks in advance!
Sergio Gzz.
MrDSM said:
Why do you want to know?
I want to know all I can about my DSM... I was wondering if it is Tach Test connection???
Does anybody knows what is???
Thanks!
Sergio G
Thanks!
Sergio G
Yes, it is your Tach connection. I however can never get mine to work properly. The tach I am using doesn't register the engine speed properly... Maybe because I have a '90... I don't know. Maybe there is another type of Tach I need to get, but, I have seen the functionality of the connection. I have tried 2 tachs and all I can see is that the tach in the car shuts off and I can get a reading, if I rev the engine, so, I know it is at least partially working. :) I hope that helps.
Mike
trbotaln said:
if your tach doesn't work then their is probably something wrong with your primary ignition.
Didn't want to hijack the post... but, my in car tach works fine... it's the diagnostic tachs that don't work and when I hook them up to the test connections, they shut off the in car tach until I unplug them. Is it not supposed to do that? I was just giving that information, just in case we need to use a different type of diag tach for our cars. I have one for DIS systems, so, I couldn't imagine what I would need. Just a thought.
Mike
Thanks!!! :thumb:
My purpose is to connect an aftermarket monster tach but I was wondering if that connection will help to do that.... I know the better way is to take the tach signal from the ECU but if that test connection works, that will be easier....
I will try to test my monster tach from there... hope it works
Thanks! :barf:
Sergio G
