aem wideband white wire
but
190
Apr 7, 2009
Ridgecrest, California
i am installing my AEM wideband and where do i tap the white wire to? (0-5v) I am going to be logging with dsmlink
Thanks man i appreciate your help! So the purple wire i just leave not connected right? so i could tap the white wire into my stock o2 sensor input?
I dont think you can do that, as the stock o2 sensor reads 0-1volt the wideband ranges from 0-5 volts.
1G ECU Pinouts
If I remember correctly a lot of guys use the Pin 15, which was origionally used for the EGR temp sensor on California emissions vehicles (and all 94's according to vfaq)
thanks guys i will look what color wire pin 15 are tonight and solder the white wire in. Just for clarification the purple is not needed? you guys are way smart!
It has been so long since i wired up my AEM wideband i honestly dont remember the colors LOL... If memory serves (which it probably doesnt) they were red black blue and white. my blue and white wires are currently not connected to anything.... until my ecmlink setup arrives.
