- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- GT42 Variant
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Drag Race
- Mods-Bolt-on
- garett gt42 jb ,shearer fab top mount manifold,tial 44mm wastegate,4" exh,ets 5" fmic ,magnus intake manifold,tial bov, coil on plug,aeromotive pro series fuel pump and regulator,1600cc fuel injectors, victory performance fuel rail
- Mods-Engine
- 6 bolt 2.0l block,arp l19 headstuds,kevlar timing belt,balance shaft eliminator kit, custom ross pistons , aluminum rods,hks adj cam gears,90mm throttlebody,bc cams,cometic hg ported and polished head, supertech dual valvesprings, 1mm over int/exh valves titainium retainers
- Mods-EMS & Logging
- aem ems, boost gauge, oil pressure, rpm, aem wide band ,coolant temp,msd dis2
- Mods-Drivetrain
- shep stg4 trans, drive shaft shop 3" driveshaft, dss stg4 rear axles, 300m transfer case stock front axles,three speed scatter shield,quatermaster 7.25 v-drive clutch
- Mods-Handling
- power slot rotors hawk pads,goodridge stainless steel brake lines,skunk2 coil overs, tokico illumina struts,10point chromoly roll cage,parachute mount,window net, volk te37 16x8 +42 offset, hoosier qtp slicks 26x9.5x16
- Parts Wishlist
- front tubular k member (99gst_racer) lol
- Background
- I got this car when I was in high school, best thing ever at the height of import racing in my area. I planned on building for drag racing only.
- 1/4 Mile E/T
- 14.630
- 1/4 Mile MPH
- 104.000
- 1/8 Mile E/T
- 10.050
- 1/8 Mile MPH
- 83.500
- 60' Time
- 3.090
- Dyno TQ
- 444.0 lb/ft
Videos
Two step teaser
Quick video of testing the two step
gt42 turbo
aem ems
gt42 turbo
aem ems
