AEM AEM v1 6 bolt CAS
Hard AttacK
32
4
Feb 15, 2011
penn, Pennsylvania
Hello thanks for looking. About to do first start on my longtime project, a 4g63 6bolt swapped Stealth. Everything *appears* to be ready except for the CAS setting. I have the factory green top 6 bolt CAS and I also have that selected in the CAS/crank sensor wizard.
Are these the default settings for the DSM CAS or does changing these settings over ride the wizard?
Thank you!
Yes, in AEMPro.
In AEMTuner, the Crank Alt Fire and Ing + 1/4 tooth are not checked as default.
Thank you very much I really appreciate the response. I can feel a little more relieved about that!! The car started for a few seconds and runs with half throttle, currently taking the cautious approach to this.
