AEM AEM EMS. V1 or V2
Yes but which one for map sensor + iat
Why don't you just select one that is named with "MAP" if you use a MAP sensor? And IIRC some startup files even have a description.
i know i need a file for aemtunerpro i mean
I don't know what exactly you plan. But if you want to use a standalone ecu, at least you have to know what you are doing.
You are misunderstanding. AEMPro, AEMTuner and Tuner Pro are three different things. If you use AEM, AEMPro for V1 and AEMTuner for V2 and EMS-4, and InfinityTuner for Infinity. And for logging, AEMlog for V1 (can be used with V2 with older firmware), AEMdata for V2 and Infinity.
And you seem thinking about the "File" as something to install and make the car running immediately, something very useful... If you are hoping to find such a file, then forget about it. Usually you won't find it. "The file" is what you have to make it from a blank file or a startup file that comes with the software by yourself or pay a tuner to make it for you. And the files that come with AEMPro or AEMTuner is startup files which is just to barely start up the engine and in many cases it would still require to change some parameters, assignments etc by yourself to start up the engine. To start up the engine is the first hard part when you switch to a standalone. And many people even give up at this point. And to drive the car, you would have to work much more.
You should read this manual.
Here is the AEM startup calibration file for the 1G 1300 EMS set up with speed density. They are using a GM 3-bar MAP & GM IAT sensor is this calibration.
Please note that this file is provided by AEM so you can start your car, nothing more, & you will need to tune it for your specific vehicle. AEM deliberately made this to be safe & is de-tuned considerable to help you avoid doing damage to your motor. They run like crap & will probably not be very drive-able as is.
Does it run A/C?
Have you gone to AEM's website & download the tuning software "AEMPro" that came with the V1 for tuning?
Yes, I'm running V1 since 2003 and daily drive like OEM. Works well when setup proper.
What Map sensor and IAT do you have bro?
Me, AEM 5-bar & IAT is the MAF temp. sensor. In case you haven't figured it out, what I have has nothing to do with the AEM start calibration file you keep asking for. BTW-the calibration file is the file from the AEM software install which is part of the software package from AEM.
Could you send me a picture? I would like to see it I mean engine bay sensors
