AEM Start up calibrations map AEM EMS v1
ScSmooth
32
May 25, 2013
Climax, New York
I been trying to get my GSX started for a few months. With work and two little ones haven't had much free time. I can connect to the EMS. Load the base map and the car doesn't start. I change the base map for the upgrades that were done and still doesn't start. It cranks but doesn't run. I hook up the factor ECU to see if the car will start. It start up and runs fine. The only issue with having the stock ECU in is when I out the car into gear it stalls out.
EMS series 1 30-1310
1998 Eclipse GSX 4G63 auto trans
Big 16G turbo, FIC 1150cc Injectors, Greddy type RS bov, God Speed front mount intercooler, AEM Gauge-Type Uego controller 30-4100, AEM 320lph fuel pump 50-1200, Aftermarket fuel pressure regulator (Looks like an Ebay, one came with the car), Everything else is stock, 93 octane gas
Just looking for something to get the car running. Then I can tune after. Thank you for any help you can give me.
It runs like crap with the stock ECU. I just put is in to see if it started. I will try and upload the file as soon as I get home from work.
Did you start with the appropriate AEM supplied startup calibration file? These are supplied to start your car so you can begin tuning for your setup. If not use the compare tool inside AEMPro and check all the setup option settings between your calibration & the AEM startup calibration for our 2G DSM's. These are loaded during the software install.
I uploaded the base map and one I messed with offline. I pretty sure I setup all the sensor and parameters.
Why did you name your cal files with 1312? Where did you get 1312 from? Does it mean anything special like this cal file is from the EMS 30-1312? If so try switching to the startup cal for the 1310 box which is the file for 2G DSM's. The correct startup cal should make your car run well enough to start adjusting you maps.
That what came with the software. I did rename it. I'll change it to 1310. I'll let you know if it work.
Thank you all for helping me out with this.
Changing the file name is not going to change the program. You need to use the startup cal file for our cars. It will start with 1310. The one you are using is for the 3G 2.4l N/T. It's will also be with the software along with every other plug'n play platform startup cals AEM makes these boxes for.
Ok so here is the latest. Being that I had time and didn't have kids running around while I was doing this.
I start AEMpro, connect to the ECM. When trying to load the start up cal. I get a popup said: No File For ECU Version So I run the ECU Setup Wizard just said: Could Not Find AEM Configuration File
