AEM 2g AEM EMS v1 spark no fuel 6 bolt swap
ceedawg
Supporting Member
1,527
216
Nov 9, 2002
laurelton, New York
Weird but car had been down since 2k8. That was the last time it ran with the aem and ran beautifully. Put in new motor(new 6 bolt motor had 6 bolt in prior) get spark but not fuel leaving fuel line. What happened?
I've had something similar happen, didn't have any fuel after an engine build. Than i realized that i disabled my injectors before pulling the motor to depressurise the fuel system.
Go to Options > Injector and make sure they are still enabled.
Try checking all your wiring.
You could also try swapping drivers, there are 4 extra injector drivers. The 4g63 firing order is 1-3-4-2 under the injectors phasing window you can move them around. But more than likely since they all stopped working at the same time my bet is it's probably just something silly, it usually is.
The motor does crank and I do have spark. Took the feed off the fuel rail and I have no fuel coming out when I turn on the ignition and swing the key.
Thing is I never went in AEM interface to disable anything since I'm not familiar with it. My tuner back in 2k3(turbo trix) were the last folks to ever touch it and it ran fine. Software has not been updated sine then.
You better believe I'm gonna start educating myself now on this thing.
However long story short car has spark but no fuel leaving fuel feed. Strange.WTF Unfortunately my car is an hour away wont get to it till friday coming. Just loaded the Software update on my laptop but I will still need help in knowing what to do.
    • george bromwell
    • pma1123
    • Sdcryan1
