twicks69
Supporting Vendor
- 4,333
- 2,073
- Mar 12, 2004
Milwaukee,
Wisconsin
Need a bit of help with troubleshooting AEM EMS V1 1.19 firmware on a fuel injector no firing issue. The entire car is brand new including all the wiring harness. High impedence 2200's with resistor pack delete plug, noid light show no fire on all 4 injectors while cranking.
Kiggly 12-tooth V1 crank sensor, 1990 CAS with modified trigger wheel; followed Kevin Kwiatkowski's trigger instructions and parameters for AEM EMS V1.
I am not sure if I am dealing with a bad cam/crank sensor or if its a wiring issue, or simply a tune issue. What tests can I do for ruling out a cam or crank sensor causing the no fire of the injectors? Is there a way to test fire each injector in AEM EMS?
I can't attach a .cal file for review, so email me at [email protected] if you can help and I'll shoot over the .cal and .dat files, and it can be looked at in AEM Pro or AEM Tuner.
