adjustable lower control arm
they are not rubbing on the fender right now but if i pull the top out it will.
do you know where i can get some adjustable lower control arms?
the car has been lowerd 2 inches
They don't exist. And 2inches is much too low from any performance stand point.
What are your alignment specs?
What suspension setup are you using? Shocks? Springs? Full coilovers? (Hint: update your car profile)
As mentioned, you have to either:
a) leave it and suffer tire wear, though toe is the real killer.
b) raise the car and use an appropriate camber kit, or just rock some camber.
if a), then c).
c) save money for new shocks, cause unless you have a fantastic setup the inevitable awaits.
