Lower control arm
1992_Talon_tsi
384
Dec 20, 2009
MIAMI, Florida
Guys i need help cant thigh in all the way the screw that goes to the brake. I thigh it up a little bit but couldnt go completely in because the bolt start spinning what type of tool could i use to hold the bolt and get it thigh. What im talking about its what you see hanging in the pic the part that conects to the brake that has a bolt..
yup can't see pic either. Upload again. Bolts probably stripped, might need a tap and die set. Or worst case scenario is helicoil. Pull the bolt out and make sure the threads aren't stripped
Dam it wont let me put the pic up anyways the bolt looked good by now i think it should be bent because i been driving around with it but anyways i could get a new one the problem its that the screw get to a point that the bolt starts spinning and it wont go in i tried many things to hold the bolt and nothing i dont know what to do if i take it to a shop theyr going to try to rape me..
