A/T 98 Eclipse Rs Tranny (Pic included)
way2slowtalon
147
Oct 24, 2004
Newington, Connecticut
I have a oil leak near the Tranny. Not sure if it is rear-main or my A/T pan gasket.
#26134 Is a "Oil pan gasket"
Is this actually an oil pan, or A/T fluid pan?
Your A/T fluid is an oil. Therefore, A/T Fluid Pan and Transmission Oil Pan are the same.
Don't forget to check the Front Pump Seal. Those go out on automatics more often than the pan gasket. I would not over look the axle seals, either, since one of them in near that area as well.
Good luck with getting that fixed.
