Calan
DSM Wiseman
- 7,250
- 399
- Jan 16, 2007
OKC,
Oklahoma
See mods in profile (except for Walbro and AFPR, which aren't installed yet)
While I'm waiting for my fuel goodies to get here, thought I would try to learn a bit about something I don't quite understand.
Basically... if I can adjust to run rich (even to the point that the car stutters, black smoke, etc), why/how would the 255 FP and AFPR upgrade help? How do these mods affect fuel-cut, MAF-T tuning, and performance in general?
I understand that the MAF-T is "lying" to the ECU about airflow, causing the ECU to do it's thing. But what I don't understand is ... for a given amount of airflow and the ECU obviously managing to get gas into the cylinders, how can additional fuel pressure or flow improve things?
Without the fuel mods yet... O2 sensor cycles as expected on logger, my o2 trim is hovering around 100% at cruise, and mid/high trims are around 105-120% after short amount of drive time since reset. I'm running 12-15 PSI boost, although I haven't really gotten on it due to some knock issues. (I replaced my knock sensor and still have some PK
... but that is another story).
I'm an old V8 shade tree mechanic and I'm still learning this DSM tuning.... just need some gaps filled in...
Thanks as always!
Calan
... but that is another story).I'm an old V8 shade tree mechanic and I'm still learning this DSM tuning.... just need some gaps filled in...
Thanks as always!
Calan
, so this is a necessary step in your upgrade path.
