95 awd auto trans?
95twinturboawd
240
Feb 26, 2009
jackson, Michigan
Just picked up a 95 awd auto with 156,000 it shifts really hard from time to time, I see I can get a jdm awd auto trans With tc for 300.00. I've had good luck with my other jdm engine and 5 speed.
are they the same?
Hoe much does it cost for a rebuild?
Any other ideas
thanks for your time/info
The shop I got it from said it had new fluid as well
if it shifts hard all the time that is a good thing it means the tranny is in good shape but from time to time u may just need a filter change amd a flush
its from time to time, and today came to a stoplight and then step on the gas and nothing, turned off car put it in D nothing, so put it in R then back in drive and it work fine the rest of the day
A lot of shops will just do a trans flush (without changing the filter!) when servicing a auto trans. This is due to the fact that trans pans are prone to leaking after being removed. I would go get a filter, new fluid & my preference is a oem trans pan gasket from the dealer. The oem is a very thick paper gasket vs the more comment aftermarket cork gasket. Remove the pan, inside it you'll find 3 magnets, check them for metal. If only a thick paste is on them then change the filter & make sure when you refill it the fluid level is correct.
I had some shifting issues with my auto. This made them better, the thing that really helped was a good shift kit though. :thumb:
