Tarzan01
- 0
- Mar 8, 2009
Spokane,
Washington
I have searched for a couple hours now and haven't found my particular problem.
I am working on my daughters '90 eclipse with a 1.8L automatic,the ecm stopped working.It took me 3 days to track it down.
To begin with it wouldn't start.No fuel delivery.I replaced the fuel pump and the fuel regulator.Still would not start.
I then started reading threads on cars that wont start and no fuel problems.
A common theme seems to be the ecu goes bad.I have an extra ecu from a '93
eclipse that had a 1.8L w a manual trans.I installed this one figuring that it might start the car but not be compatible with the auto transmission.The car starts and runs now so I drove it a around the block to see if it would shift ok.It does.
Both ecu's have different part numbers.The cars seems to run fine with the one I installed, but can anyone tell me if I am missing something.Is this ecu compatible or will it mess the car up?
