1G 92 plymouth laser starting issue.
Sal
Mar 23, 2016
Phoenix, Arizona
Hello, I bought a 1992 plymouth laser rs, and it refuses to start. I have so far changed the starter, battery, and spark plugs. When I put the key in the "on" position all it does is make a constant clicking noise, or like a relay turning flipping on and off. Any ideas on what it could be? Thanks
take off the knee bolster and steering column plastics, then test your ignition harness in all positions to make sure you have proper voltage. I don't recall the colors but I can get them for you tomorrow.
U could short cut to checking the solenoid on the starter is getting voltage when you turn the key to run as well
Check all your grounds and make sure they test good with continuity. Past that I don't recall if there is a starter "relay" so check the under hood fuse box for one and verify if it's working.
Okay there is a contious ticking coming from the throttle body sensor, any ideas why that wouldnt cause it to start?
When you turn the key on to accessory does the IPC light up? If everything is dark and nothing happens pull the ecu and check it's condition.
