1SloEvo
- 1,068
- 22
- Mar 7, 2010
Warner Robins,
Georgia
I just picked up a FWD 1990 Laser RS-T. I've always been a fan of the 14b, so I'll be playing around with the stock turbo to see what I can do. The plan is to get everything mechanically sound (car runs decent now, but I need to adjust some balance shaft belts and make sure the timing is spot on), and get it ready to hit the track in stock trim with no mods other than an air filter (since the car came with a filter when I bought it). The only other "mods" it has are a sway bar, boost gauge, 8mm spark plug wires, NGK BPR7ES plugs gapped at .026" and shifter base bushings. For the most part, it's pretty stock. I'm hoping to hit the track within the next couple of weeks in stock form. Once I get a baseline, I'll slowly start dropping the weight of the car, as well as adding some performance parts I am currently collecting.
I'll try to get some pictures posted up in the next couple of days. The car is relatively clean, so there won't need to be any body or paint work to the car. Keep an eye out for updates, changes and results and the car progresses!
Here are some pictures of the outside. The interior is just as clean, minus a missing headliner.
I also found this in the wiring to the ECU. Not sure what it was used for. It was connected to the pins for MPI relay power and a ground. Once removed, I haven't seen any change in the car. I tested the MPI relay to make sure it was GTG...no issues with it.
