-8AN fuel lines
Im in the middle of putting -8an inlet and -6an out on my car now. Not to steal the thread but anyone know where I can find a -8 fitting for the fuel rail? Group buy?
Please take notice of the section of the forum you're posting in: 420A Bolt-On Tech. 4G63 technical discussions belong elsewhere... (posts deleted)
Wow that was really weird, LOL. That other post was on there for the 4g63 fitting and it was gone just like that right when I was looking at it. Then I saw Pauls post.
So I take it that fitting was for the 4g63 rail?
Sorry Paul, wasn't paying attention :coy:
rstare: Yes, the link I posted was a 4g63 fitting.
I'm running -8an with -6an return as well. No problems except setting up the dual walbros (finding a y to use). Fuel pressure will obviously change from set-up to set-up but I am running 37 psi on my aeromotive with 880 injectors on MSnS. But that will change as I raise my power.
Oh, the vac port to block off is the line coming FROM your intake source (after you take it off your regulator. You do that so the car runs without an intake leak.
MB
looking to build custom 8AN fuel system.
Something to support GT40R or simmilar..
found Aeromotive pump..but its 10AN.. Aeromotive A1000 Fuel Pump - Modern Automotive Performance
another way is get twin Wallys..but whats worth..mean get another In line wally is like 130usd, next 2x one way check valves its 120usd then fittings and lines to get them in one line 6AN to 8AN...BTW Iam not sure which fittings I should get..using only return line kit from SBR..
Anyone who build this 8AN system for 800+HP
Can you send me list of parts I need
Thank you very much
Venca
Thank you very much
Venca
Your in the 420a forums and I dont think any of the 420a guys have 800hp LOL.
    • george bromwell
    • pma1123
    • Sdcryan1
