67mm holset???
gsxkid81
140
May 18, 2005
warsaw, Virginia
i searched and could not find anything.but i was wounder if there are any 67mm holset turbos with t3.i am would like to compare the holset up against my 6765.any info would be appreciated.
No there aren't, the 67mm is an hx52 t4 16cm housing. That big of a turbo would choke out on a t3
damn i hate to have to change to a t4 manifold for some testing.is the billet hx52 pro a 67mm wheel?
They both flow 90 lbs a min in a t4 housing. From my readings the hx52 spools up faster then the precision 6765 but not by too much
Some of the billet pros are 72mm mine is a factory billet and is a 67mm
