Holset H1E
SlowChild3
545
9
Aug 19, 2005
Dayton, Ohio
I'm having a hard time finding some info on this turbo. The number is 3530769.
Compressor 81.9 mm 50.038 mm
Turbine 76.07 mm 64mm
18cm housing
Twin scroll
I'm curious to know how much power this turbo can make.
The Wh1e is like it's little brother the Wh1c. It mirrors the hx40 8blade in every way except that it has a v-band compressor cover and a 4bolt chra-turbinehousing pattern. It will consequently bolt into the hx40 bep bolton turbine housing and this is plenty of flow to max out its 60lb/min compressor.
The h1e is like it's little brother the h1c. There are different size compressors. . . BUT there are also different size turbine wheels too. Check measurements before buying this turbo if you plan on running a BEP turbine housing. There are lower flowing compressors than the 58mm 8blade that are out there. So this turbo may not flow any more than an hx35 if get the wrong one. You need at least a 58mm compressor inducer for this to be a worthwhile turbo vs the proven hx35 or 8blade hx40.
Is in the Holset pin thread:thumb:
Here is what I could find on it.
"The h1e is like it's little brother the h1c. There are different size compressors. . . BUT there are also different size turbine wheels too. Check measurements before buying this turbo if you plan on running a BEP turbine housing. There are lower flowing compressors than the 58mm 8blade that are out there. So this turbo may not flow any more than an hx35 if get the wrong one. You need at least a 58mm compressor inducer for this to be a worthwhile turbo vs the proven hx35 or 8blade hx40."
Ya I've read all that. It has the baby 50mm compressor. What can I reference that to for flow?
It also has a 2.5" exhaust outlet.
