2G 6 Bolt with a 2G motor mount modified for the timing belt tool
Justin DuBois
DSM Wiseman
3,326
3,297
Aug 15, 2019
Oakland, California
Someone out there has figured out how to modify a 2G motor mount so that the 1G 6 bolt timing belt tensioner can be compressed with long threaded bolt.
Any help on how to do the mod is much appreciated. I have a spare motor mount, and a timing belt job coming up, and I'd like to swap out the motor mount while doing the water pump and all so that I can do a timing belt task easier next time.
Who's done it?
Every return belt I've ever done I can just put the pin back in the tensioner when removing the belt. For the ones that I cant, I just use the eccentric pulley tool and turn the eccentric until I can put the pin in. I haven't used my threaded bolt in probably 10+ years.
My solution to this has been to just build up this little pad of weld with my tig and use the existing hole in the mount, I find it easier than drilling and tapping a hole at an awkward angle.
That is clever, maybe I can send you an arm and you can modify it!
    • Sdcryan1
