6 bolt swap what do i need?
slowmoawd
Aug 14, 2011
grand island, Nebraska
I have a 1995 eagle talon tsi awd turbo 5 speed that had crank walk i want to do a 6 bold swap i found a complete running 6 bolt engine with 69k miles out of a 1992 laser what do i need to do to drop in a go?
Lol I was feeling some one was right there getting ready to post it.
I take issue with steps 4, 6, 15
Step 4: For the transmission, do not use synchromesh, us Redlin MT-90
Step 5: For the Transfer case, use shockproof
Step 15: What starter bracket? Only thing I can think of is the starter plate between the block and the transmission. And nothing needs to be modified. If you have a 2g AWD use the 2g AWD starter plate, if you have a 2g FWD use the 2g FWD starter plate. Also, I have no idea what issues he was having with the transfer case? It WILL bolt up too the AWD transmission with zero issues.
As for priming the engine; There is no need to disconnect the fuel pump, disconnect the CAS instead, as it is far more accessible.
And I'll keep my mouth shut about the use of Royal Purple...
