6 bolt swap HELP!
fallenauthority
692
11
Oct 14, 2004
La Plata, Maryland
Ok well hi guys, my name is David, Im a DSMaholic, and I have a problem. I am right now swapping a 6 bolt shortblock into my 95 talon with DSMlink and a 2g head. Now im looking at this swap kit from slowboy http://www.slowboyracing.com/more.php?id=1053&mods=21-2991,23-2990
Now it says it has everything you need to swap a 6 bolt block with 2g head into my car. But then I keep reading about the CAS needing to be used and rewired, I thought that was only with the 6 bolt head? Please help me clear this up I need to get this finished ASAP. Appreciate the help fellas.
A 1G CAS is what makes the swap possible. Without it, you can't crank up your 6 bolt swapped car.
A 2G 7 bolt engine uses TWO seperate sensors, a Crank Angle Sensor and a Cam Angle sensor.
On a 6 bolt, both sensors are in the 1G CAS.
The 6 bolt oil pump/front case assembly does not have the mounting provisions for the Crank Angle sensor.
Hit your local junkyards and LOOK for a Black lid CAS, if you canot find one get a 91/2 Green Lid.
They cost over $300 Brand New.
Good luck
No it does not. The 2.0L turbo and non turbo uses the same CAS.
The 93-94 Hall Effect CAS does not give you the random miss fire code where as the 90 and 91-92 CAS will. You have DSM Link though, so you can turn off the random miss fire.
About the Hyundai, I'm not sure. I would stick with the E/L/T.
I would try really hard to find yourself a black lid cas from the 93-94 because I just the first one I could find (it was a 91-92 green lid for only $10) and I get random misfires all the time. To try to correct it, I constantly have to get on and off the throttle and can never use cruise. I cant wait until I get dsmlink.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
