6 bolt rebuild
madscientist323
Nov 14, 2004
philadelphia, Pennsylvania
i just got my block and crank back from the machine shop.they told me everything is fine.they honed the cylinders.and polished my crank.LOL and sold me the rings and bearings all standard size.they also recommended an assembly lube.i asked if there was any special products or other procedures i need to do or get. they told me to oil the cylinders before i install the pistons and how to move the ring gaps and to put assembly lube on the bearings where the crank touches it. and to torque the rods and mains down and that would be fine.they never said said anything about plasticguage. will it work cause the bottom end is built already i need to find out before i go too far.
thanks
larry
im probably gonna catch heat for this,but if it turns freely,your good.my stepdad helped me out and hes built a 400+hp mustang.just make sure nothing is binding.
i thought the same thing so we both will get flamed to hell
