6 bolt block rebuild checklist
KaLo_o
227
Mar 9, 2009
Quebec, QC, Canada
so i got my hands on a 6 bolt block...yay my first one! all ive had is 7 bolt 1g dsm's so far... anyways, shes in the garage with the head off, it will need to be bored out at least 0.20 since the head has been off for a while and i dont think just honing it will do it and id like to go overbore anyway! here is my checklist so far. as for the bearing sizes i will have to wait for the machinist to tell me what i need.
please let me know if i am forgeting anyting.... i jusr gt the block yesterday and make this list in about 30 minutes of thinking. this is for the block only
the block will be built in about 1 month
350 hp 6 bolt block rebuild checklist
- oil pan gasket
- front case gasket
- front main seal
- rear main seal
- bsek kit
- new oil pump and gasket
- new water pump and gasket
- new oil filter housing assembly and gasket
- new tensioner
- new timing belt and bearings
- topline stock pistons
- eagle h beam rods
- acl main bearings
- acl rod bearings
- arp headstuds
- arp main studs
- arp rod bolts
- cometic head gasket
- new oil squirters
- new oil pick up tube
- new harmonic dampener
- new flywheel bolts
Why put topline pistons over eagle rods????????? Or any cast piston for that matter???????? BTW, Topline is not OEM. The OEM replacement is made by NPR. Who makes many pistons for Mitsu, Toyota, etc.
topline pistons are a stock replacement piston i never said they were OEM, about puting those on eagle rods, whats the poblem? i was never told you cant do that so i just assumed i could. so insted of asking me the question with 12 question marks wich dosent help me more, how about you educate me a bit on that.
also is there a way to get brand new oem rods? to match those pistons then?
Aftermarket rods use floating pins. So unless you have the stock replacement pistons machined for spirolox, or retaining clips, that setup wont work.
ok thank you for your input, since my hp goal is not that much, where could i purchase some new stock rods for my setup to work? and any inputs on topline pistons? anybody used those before? or should i got with NPR
I did help you through the socratic method hence the "???????" . Socrates however taught those that were willing to research an answer.
I'm a sucker and I'll try another method this once. . . Get junk yard 6bolt rods. J_U_N_K_Y_A_R_D rods. Just have them checked (bore on both ends). And press the topline pistons on to them. The eagle rods are wasted and the cost is completely unneccesary when 6bolt rods can handle a large percentage of TWICE the power output you're shooting for.
My mention of of the difference between topline (bottemline, in my book) and OEM pistons is for you also to research. Mainly in the QC issues of topline. I've personally have had no good success with much of anything from topline with over than stock HP levels. And you're shooting for at least 100hp over stock. I have had their cranks come apart, their oil pumps fail an refuse to take a chance on a slug that keeps a rod from going through a block especially when the rod costs as much as an eagle rod.
  • For sale 2g 2G Clear Tail Light Set
    2G Clear Tail Light Set $550 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
