2G 6 bolt head 7 bolt block
shshfbdicn
Mar 27, 2024
alburtis, Pennsylvania
My 7 bolt head is cracked and causing oil burning, I got a 6 bolt head , intake manifold, and thermostat housing. How do I run the cooling system now with the 1g thermostat housing? Do I run the water pipe to the bottom radiator inlet?
Yes, you need the 1G water pipe to accompany the 1G thermostat housing, which routes to the lower radiator outlet.
Ok thank you, am I able to still keep the coolant lines for my iacv, heater core, and turbo when swapping to the 1g water pipe
Yes. Just be aware of the differences between the 1990 (no provision for return at the oil cooler) and 1991-1994 water pipes and make sure you choose the right one for what you need.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
