definitiveno
- 1,237
- 8
- Sep 8, 2004
Reno/Sacramento,
California
:thumbdown
Quit your bitching fool
gsx91b0y said:I thought the red was a 60 trim not a 60-1
*shrugs*
-aaron
*shrugs*
-aaron
red91gst said:I'll get the Dyno sheet posted later this evening.
Nate
Slowboy Racing Inc
Awdboost said:Since my post on this board, I ran a 11.544 @ 128 I couldn't grap traction in first and had to granny shift 1st to 2nd. and I even got squirrel in 2nd.![]()
This is on stock 7-bolt untouched
stock 2G head untouched
stock intake manifold
HKS 272/272
So 7-bolt have more potential then people think.
93AWDTalon1 said:You never did post your dyno sheet
Awdboost said:No, ARP head studs with stock head gasket.. I wasn't going to take that chances. There is no way the stock head studs can hold that.
I didn't know you could use 6-bolt studs in a 7-bolt motor??Awdboost said:I've also seen stock head bolt strech and blow coolant all over the place.I didn't know you could use 6-bolt studs in a 7-bolt motor??
red91gst said:Typically, there is a 16-18% drivetrain loss in a fwd car, 24% or more in and awd. If it was 551 front wheel hp, crank should be around 640. (551 * 1.16)
Nate
SBR
Batty200 said:Nate
Just a little FYI. If you are losing 16% due to drivetrain then the remaining 84% is what you saw at the wheels so the proper formula is 551/.84 which equals 655.9CrankHP.
655.9x.84 is 551. See how that works. Most people do those equations wrong.
My friend did 557whp on an AWD so that would be 557/.8 if we assume 20% loss which is 696.25CHP.
I didnt see there was another post about this.![]()
Later
drew214 said:you said money was a factor on choosing that turbo. If you had the money which of your GT turbos would you run on your car?
coltboostin said:We still waiting on a dyno sheet?
