how many pounds of boos can i do on a stock int..?????????
secretsquirrel
Aug 28, 2004
martinsville, Virginia
I Have a small 16g, web cams, prothane motor mounts, and frount mount cooler,osofast downpipe , 3 inch exaust,cm stage 3 clutch, crank pully and, 255 fuel pump, what other extras do i need and how many pounds of boost can i run?????????????????? :p
I'll second the case!
Is the newbie forum overrun or something, is that why these are ending up in the "advanced" section?
On stock injectors, 14-17 psi depending on when you start to knock/ get up around 100% idc. After an injector upgrade 16-18 psi on the stock intercooler, depending on when you start to knock from an inefficient turbo. Like so many other subjects, it really depends on the car. If you're looking for a number to start at without having to actually tune, 15psi should be ok.
Check out the "Scanmaster" at www.fullthrottlespeed.com.
For $249. (do you have a 1G) you can make tuning a snap and run as much as the quality of your fuel will allow without knock.Why guess unless you be cash-less? Mark
