5 speed swap woes
proto2
67
Dec 16, 2006
Salisbury, Maryland
I changed my 95 GS-T over to a 5 speed. Everything was working well until today and I believe it's a relay. The ignition has one of 1 relays clicking on the fuse block and the starter would try to engage but it won't spin to start the car. I'm at a loss here trying to figure it out.
Check list:
- safety switch wiring which is fine
- starter relay is fine (tested)
- terminals are clean and tight
- starter is good (tested)
Any input is greatly appreciated.
I know this. I've been 5 speed swapped for 3 years and this problem just came out of no where so it has to be electrical.
