4g69 pistons in 2.3 stroker
Cruciatus111
50
6
Oct 10, 2013
Honolulu, Hawaii
Hey guys I'm planning out my 2.4 stroker build right now, but I'm deciding on what Pistons to get, the block I'm going to use is a 6 bolt block that has been bored out to 87mm. And I plan on using an oem 100mm crank. The goal is to put down max around 400-450hp to the front wheels.
So I was wondering if any of you have had experience 4g69 pistons pressed onto 6 bolt rods and if this combination is strong enough to take my power goals, or should I just go for h-beams and forged Pistons?
It's all in your tune. I beat the piss out of a n/a 4g61 engine with a 2g head and a 14b running 22psi.... for thousands and thousands of miles with no ill gotten effects from using the n/t pistons that came in the bottom end. All I did was add squirters and tune it properly.
