420A 420a Timing belt tips
DrewmHolland
171
36
Apr 11, 2022
franklin, Tennessee
Im currently rebuilding my 420a motor from the bottom up (I have to replace main bearings and possibly resurface the crank)
Im about to pull the timing belt off but there's 2 problems 1- i cant get the stupid timing cover off without breaking it and 2 - I really just need tips for timing the motor so that I don't mess it up when I put everything back together later on
The 420a timing cover isn't split at the head and the block. So that means you have to pull the front timing cover off, pull all the timing components off, and then pull the rear timing cover off. I suggest when you get the timing covers off you cut them at the block and the head. This would essentially give you an upper and lower cover. And would allow you to pull the head without removing all the timing components just to pull the rear timing cover. I cut my timing covers on my 420a, and I only run the lower covers now too.
Just make sure all your timing marks are lined up before you remove any of the timing components as well. Hope this helps
Use one of these with the correct bolts. Usually have to add washers to the bolts since their heads are too small.
I
thanks, I went to an O'reilys to get a timing gear puller recently but they didn't have one that was a 3 bolt, do you know where I can get one?
If you put that gear on backwards you will have to tap the 3 holes and use bolts on your puller to get it out. Ask me how I know LOL. Do it right the first time. FYI get a haynes manual.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
