Resolved 420a 4G63 Fuel Injector Interchangeability
GSTurbo1
610
May 2, 2012
Pickens, SC, South Carolina
Ok so I'm doing an engine rebuild and want to make sure my 450cc injectors will feed the power i'm wanting to make. I'm trying to run close to 15-20psi, I def have all other supporting mods, but feel that my 450's are a week point. What injectors would be a good size to up to? I have been doing some reading and 420a and 4G63 are interchangeable, correct?
Thanks,
Jason
What kind of power are you trying to make? And no 4G63 injectors will not work in a 420A. Unless you wire in the resistor box or have a MS unit that will run low impedance injectors
450cc will only handle 32 lb/min at 100% IDC (assuming 43psi base pressure). Your 16g is capable of well over 30 lb/min at 20psi. Some guys have seen almost 40 lb/min at a hair above 20psi. When it comes to injectors, I suggest you go as big as your tuning device will allow. However, the mimnum size needed for your turbo on gas 650cc.
