sakroda
- 233
- 36
- May 3, 2016
İstanbul,
Europe
Hello
My engine is started to shake suddenly. the engine was shaking when I pressed the gas..I pull out 3&4 injector cables so nothing change but when i pull out the 1&2 injector cable so engine dies There is no CEL and i have datalogger i can not get any error so I started to control my car;I am turning off injectors from MMCD i can not see any difference when i turn off the 3&4 injectors
I have checked firing( I can see parks on all 4 cylinders)
Injectors resistor ohms 0.7
injector ohms are same 0,34
CAS: pin1:4v pin2:5v pin3:12V pin4: ground When i start the engine and hooked the wire pin1:1,82v pin2:2v pin3:12V pin4:ground(so they are normal values? when i spin the cas to clockwise i hear something but i am not sure injectors are working?
I have changed the spark plugs and it s all the same
I did not check coil and ignition module because i can see sparks on all cylinders
I will remove injectors and i will check they work or not
Do you have an idea? what's wrong with my car?What would you suggest to do?pls help
i will replace it tomorrow..
