BOV not working
xX-ProudDSM-Xx
96
Jul 16, 2011
Pomona, California
Ok so I just recently installed a FMIC. After everything I connected everything back and I rev my car and I can't here the BOV. I have a HKS BOV.
I was thinking it could be that it doesn't observer much pressure to make it blow. I twisted a couple of times in accident and I'm thinking I might of just messed up the ring.
Any clues?
And would a oil leak have to do anything with the BOV
with the fmic it will be harder to blow it off at idle as it now has longer route to get the boost to the intake mani, assuming u didnt use short route piping, u made sure the vaccum line was reattached? have u driven it, does it blow off that way? oil leak has nothing to do with it, sounds like its not getting the vaccum to pull it open,
Has absolutely nothing to do with the issue.
OP, where do you have your vacuum lines run? Do Not run it to the ports on your throttle body because they have tiny holes and can't supply the needed air to move that diaphragm, regardless of what you have previously read on the internet. You can run it to a port on the intake manifold seeing as how that sees pressure and vacuum and is wide enough for plenty of air supply.
Does your BOV have two ports on it? Upper and lower? If so, with the upper hooked up to a good vacuum line, does the lower port have vacuum pull on it? If so, your diaphram is bad which will keep your BOV from working, and will cause a nasty vacuum leak/boost leak.
I'm skeptical about it because when my friend had it, he also had the front mount and it worked perfectly.
I already tried the vacuum hose from the intake manifold to the BOV. Then I tried the BOV to air intake. I really dont know what it is. My previous BOV worked perfect, but the HKS one doesn't.
I kinda feel like a lot of air is coming out from somewhere ( boost leak)
did you do a vac. test on the bov. the seals inside the bov may be bad.
another thing to do would be a pressure test on your ic piping.
As BurrowZ said, take the car for a drive, make sure it sees boost and then listen for the bov.
You don't build boost when free-revving in neutral, and atmospheric pressure leaving the bov doesn't produce as much noise.
Also is the bov a knockoff? I opted to install the free knock-off that i got from a friend, however the check valve inside wasn't very effective and the spring was too stiff. Currently the bov doesn't have a spring at all, but I am much happier without compressor surge :thumb:
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
