2nd Gear Pull Log -- Help!
aspekt9
344
4
Dec 25, 2005
Boston, Massachusetts
2nd to 3rd gear conservative pull, how does it look?
Code:
TIME	TIMA	FTRL	FTRM	FTRH	FTO2	O2-R	TPS 	MAFS	ERPM	KNCK
6/19/2009 16:25	31.00º	81.12%	95.16%	81.12%	31.20%	0.78V	23.14%	270.47Hz	2500.00rpm	0
6/19/2009 16:25	31.00º	81.12%	95.16%	81.12%	32.76%	0.66V	23.14%	276.76Hz	2562.50rpm	0
6/19/2009 16:25	31.00º	81.12%	95.16%	81.12%	31.20%	0.64V	23.14%	283.05Hz	2593.75rpm	0
6/19/2009 16:25	32.00º	81.12%	95.16%	81.12%	32.76%	0.68V	23.53%	289.34Hz	2625.00rpm	0
6/19/2009 16:25	32.00º	81.12%	95.16%	81.12%	33.54%	0.45V	23.92%	301.92Hz	2718.75rpm	0
6/19/2009 16:25	32.00º	81.12%	95.16%	81.12%	34.32%	0.88V	24.31%	308.21Hz	2750.00rpm	0
6/19/2009 16:25	32.00º	81.12%	95.16%	81.12%	32.76%	0.70V	24.71%	314.50Hz	2812.50rpm	0
6/19/2009 16:25	32.00º	81.12%	95.16%	81.12%	31.20%	0.49V	25.49%	327.08Hz	2875.00rpm	0
6/19/2009 16:25	32.00º	81.12%	95.16%	81.12%	39.00%	0.90V	25.49%	339.66Hz	2937.50rpm	0
6/19/2009 16:25	33.00º	81.12%	95.16%	81.12%	31.20%	0.76V	25.88%	352.24Hz	3000.00rpm	0
6/19/2009 16:25	33.00º	81.12%	95.16%	81.12%	34.32%	0.41V	26.27%	352.24Hz	3062.50rpm	0
6/19/2009 16:25	33.00º	81.12%	95.16%	81.12%	36.66%	0.86V	26.67%	371.11Hz	3125.00rpm	0
6/19/2009 16:25	33.00º	81.12%	95.16%	81.12%	42.90%	0.27V	27.06%	377.40Hz	3187.50rpm	0
6/19/2009 16:25	33.00º	81.12%	95.16%	81.12%	56.16%	0.90V	29.80%	408.85Hz	3281.25rpm	0
6/19/2009 16:25	30.00º	81.12%	95.16%	81.12%	99.84%	0.16V	52.94%	610.13Hz	3406.25rpm	0
6/19/2009 16:25	27.00º	81.12%	95.16%	81.12%	99.84%	0.96V	70.98%	691.90Hz	3562.50rpm	0
6/19/2009 16:25	26.00º	81.12%	95.16%	81.12%	99.84%	0.96V	79.22%	773.67Hz	3843.75rpm	0
6/19/2009 16:25	26.00º	81.12%	95.16%	81.12%	99.84%	0.96V	82.75%	886.89Hz	4031.25rpm	0
6/19/2009 16:25	24.00º	81.12%	95.16%	81.12%	99.84%	0.96V	91.37%	1018.98Hz	4281.25rpm	0
6/19/2009 16:25	24.00º	81.12%	95.16%	81.12%	99.84%	0.96V	99.61%	1188.81Hz	4562.50rpm	0
6/19/2009 16:25	20.00º	81.12%	95.16%	81.12%	99.84%	0.96V	99.61%	1534.76Hz	4968.75rpm	0
6/19/2009 16:25	19.00º	81.12%	95.16%	81.12%	99.84%	0.96V	99.61%	1603.95Hz	5375.00rpm	0
6/19/2009 16:25	21.00º	81.12%	95.16%	81.12%	99.84%	0.94V	99.61%	1603.95Hz	5531.25rpm	0
6/19/2009 16:25	23.00º	81.12%	95.16%	81.12%	99.84%	0.94V	69.41%	1603.95Hz	5843.75rpm	0
6/19/2009 16:25	29.00º	81.12%	95.16%	81.12%	99.84%	0.78V	10.59%	201.28Hz	4906.25rpm	0
6/19/2009 16:25	45.00º	81.12%	95.16%	81.12%	99.84%	0.94V	64.31%	899.47Hz	4281.25rpm	0
6/19/2009 16:25	25.00º	81.12%	95.16%	81.12%	99.84%	0.96V	95.29%	830.28Hz	4000.00rpm	0
6/19/2009 16:25	25.00º	81.12%	95.16%	81.12%	99.84%	0.96V	99.61%	956.08Hz	4062.50rpm	0
6/19/2009 16:25	23.00º	81.12%	95.16%	81.12%	99.84%	0.96V	99.61%	1018.98Hz	4125.00rpm	0
6/19/2009 16:25	22.00º	81.12%	95.16%	81.12%	99.84%	0.96V	99.61%	1113.33Hz	4312.50rpm	0
6/19/2009 16:25	21.00º	81.12%	95.16%	81.12%	99.84%	0.96V	93.33%	1213.97Hz	4375.00rpm	0
6/19/2009 16:25	19.00º	81.12%	95.16%	81.12%	99.84%	0.96V	34.12%	1100.75Hz	4468.75rpm	0
6/19/2009 16:25	29.00º	81.12%	95.16%	81.12%	99.84%	0.97V	10.59%	125.80Hz	4562.50rpm	0
6/19/2009 16:26	44.00º	81.12%	95.16%	81.12%	99.84%	0.94V	10.59%		4375.00rpm	0
6/19/2009 16:26	43.00º	81.12%	95.16%	81.12%	99.84%	0.68V	10.59%	50.32Hz	4343.75rpm	0
6/19/2009 16:26	43.00º	81.12%	95.16%	81.12%	99.84%	0.47V	10.59%	37.74Hz	4250.00rpm	0
6/19/2009 16:26	43.00º	81.12%	95.16%	81.12%	99.84%	0.33V	10.59%	37.74Hz	4218.75rpm	0
6/19/2009 16:26	42.00º	81.12%	95.16%	81.12%	99.84%	0.29V	10.59%	37.74Hz	4187.50rpm	0
6/19/2009 16:26	42.00º	81.12%	95.16%	81.12%	99.84%	0.25V	10.59%	50.32Hz	4187.50rpm	0
6/19/2009 16:26	42.00º	81.12%	95.16%	81.12%	99.84%	0.23V	10.59%	44.03Hz	4093.75rpm	0
