Resolved 2G Wiring harness routing and connector identification
akdov823
255
31
Sep 20, 2014
feeding hills, Massachusetts
My project is going slow, but it's finally time to start plugging thing back in. The problem is I can't find my pictures of the routing of the wiring harness. I was hoping maybe someone had a picture of the harness installed, that I could pick up some key location off of.... .hope this makes sense because I'm in the garage trying to type on my phone
specifically around the intake manifold. throttle body, coil pack, that area. i just cant seem to find the right combo to make the plugs reach and make sense
fsm? its a 96 talon with a swapped 6 bolt. i do have the service manual and there is a configuration diagram, but i really need to see a picture to understand where the injector bundle(plastic incased wiring)goes. is it stuffed in between the intake?
This may help.
also it seems there are two of the same connectors, one goes to the coil pack and the other to the cas adapter but i do not know how to identify which is which
that does help, i forgot my 6 bolt intake doesnt have the same mounting points
Wire colors. If you have the FSM, you can easily refer to it to find that:
  • The crank sensor has a black wire at pin 1, blue w/ white stripe at pin 2, and red wire at pin 3.
  • The coil pack has a blue w/ black stripe at pin 1, a blue w/ red stripe at pin 2, and a black w/ white stripe at pin 3.
well now i just feel ridiculous, but thanks non the less
Help id this single "ground"? I can't figure how to read the wire diagram in the manual
Also looking for the other end of the started wire. Can not find the connector
Scratch the starter...thats a stupid connector, looks like a double wire..haha
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
