2g mas on 1g with 4inch inlet on turbo
nytescion
602
Jun 25, 2007
Woodbridge, Virginia
For the guys that are using a 2g mas with a 4 inch inlet turbo what are you using as intake pipe. I currently have a 3inch round pipe on my 1g mas but now i need to upgrade to 2g mas, I'm pretty sure using the round pipe is not going to work though.
There is just not enough room between the turbo and the fenderwell to fit it all in. The FP pipe is a bit to long. It says it right on their website. To bad, because its half the price of the Dejon pipe plus its aluminum over steel.
The FP intake pipe would be perfect. 4" inlet, and it ovals out to fit a 2G MAS perfectly.
Mine worked just fine.
With 2G mas you could run the APC shorty filter (just do not run the filter without the 2G mas there). OR you'll end up like i did with my FPHTA88 turbo.
But 20psi on the 2G mas on the 4" inlet turbo, FP 4" intake pipe (2 FP 4in couplers), APC filter.
Fit tightly but as a quick fix, its just fine. Just DO NOT USE THE APC FILTER WITHOUT THE 2G MAS there (incase it comes apart like they do).
