2g MAS on 1g Motor??
90GSXDan
224
Aug 8, 2004
Long Island, New York
Hello,
I was wondering if I could put a 2g MAS on my 90 GSX? If so, how can it be done?
Do I need a new intake pipe? And a new 2g MAS?
Thanks
Dan :dsm:
What about a blow-through setup? How does that work? Thats so I can vent to the atmosphere right?
Would I run leaner? Richer?
Thanks
Dan :dsm:
2g MAF's are setup like you see in the vfaq, where the air is drawn through, not blown through, so it is run off the turbo's inlet. If you want a blow through setup, look into the GM MAF setup. You can set that up draw or blow thru. If you set it up blowthru after the BOV, then yes you can vent just fine. It's all about the benjamins, if you got the money, get the GM MAF, if not, 2g MAF's have proven to handle some power.
