Please Support Rix Racing
RoasT BeeF's Eclipse GSX
Mitsubishi Eclipse GSX
FP3065, AMS VSR SMIM, Strictly Modified 75mm Billet TB, Dejon Race FMIC - 3" Cold Side, Tial Bov, FP Exhaust Mani, FP30 Recirculated O2 Housing, Tial 44mm Wastegate, Thermal R&D 3" Exhaust, Rewired Walbro 255, -6 AN Fuel Feed, FIC Blu Max 1250s, Aeromotive AFPR, Visteon Aluminum Radiator, Prothane Mounts, Sparco Torino Seats
Mods-Engine
Block - Ross 8.5:1, Eagle H-Beam Rods, ARP Rod and Mains, Balance Shafts Removed - - Head - SS O-Ringed, HKS 272/272, Fidanza Cam Gears, 1mm Oversized, Black Nitrate Coated SS valves, 5 angle valve job, MADD Springs -- Removed Power Steering and A/C
Mods-EMS & Logging
DSMLink V3, AEM UEGO, AEM 5 Bar Map, GM IAT
Mods-Drivetrain
Shep Stage 3, 4 Spider Center, Evo III 1st, Exedy Chromoly Flywheel, Exedy Cerametallic 2160 3 Puck, SS Clutch Line, Symborski Shifter Base Kit, Shep Cable Bracket and Cable End Bushings, Shep Pedal Assembly, Three Speed Scattershield
RMDSM Rear Sway Bar, Energy Suspension Control Arm/Sway Bar Bushings, Tein SS Coilovers, Ceramix Pads, Cross Drilled Front Rotors, Dual Piston Front Calipers, SS Brake Lines
Parts Wishlist
Paint Job
1/8 Mile E/T
8.322
1/8 Mile MPH
95.910
Timeslip Photo Link
Timeslip Details
Track Name : Bandimere Speedway
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : 3190
Tires : Street Radials
Altitude : 6000
Sponsored Car : no
0.0 lb/ft
RoasT BeeF
More in 1G DSM
Share this Vehicle
