2g MAF plug and play in 1g
compass
Aug 2, 2006
Denver, Colorado
I just put a 2g MAF in my '93 Talon TSI, and it runs like crap! I used the tech section on this site about wiring the 2g plug to the 1g plug. I ran the engine at idle,(crap) drove around the block (crap), than I unpluged the 2g MAF and it ran the same, like crap. Is my 2g MAF bad ? Do I need a piggy back system or what did i F-UP ?
The reason why it runs like CRAP is because the 2g has a higher air flow than the 1g, therefore leaning out your a/f ratios. People say install 550's and it will run alright, but not fully correct. The only other way would be to add bigger injectors and get the SAFC and logger and tune that way.
Why dose the car run the same with the 2g MAF unpluged or pluged?
thanks
compass said:
No, should I ?
Heck yes you should.
When you change your airflow, you should always be thinking about how you're going to match it with fuel effectively. And the best practice is to know the answer and have the particular fuel/control hardware on hand before you start.
You should have researched before swapping to a 2g maf. Its not a drop in part, you at least need 550's and this would still cause you to run a little rich, which is 10 times better than a little lean. I would put the 1gmaf back untill you get an AFC and some 550's
thanks
Because the ECU is running off of stored values in the fuel maps. You need some sort of fuel management, a piggyback fuel controller would be a good place to start. Like others have said, 550's would work to get you by, but even then its still running a bit rich. Look in the classifieds, or on eBay. There are a few Apexi SAFC in the classifieds for around $150, and the same on eBay. Plus if you are planning on modding in the future, like bigger turbos and such, you are going to need one anyway. But if i were you, I'd look into your ecu and see if it is eprom, because if it is, i'd be saving for dsmlink as that would be my next mod, completly stock or not.
So going back to a 1g MAF is the best way ? Than find a piggy back to run my 2g MAF later.
Will any AFC work on my car ???
Sorry for being such a dumb a$$
Car: 1993 TSI, IC pipe with SMIC, turbo header, 16g turbo, 2.5" turbo back, ported intake, ported head IN/EX with 3 angle valves.
Yeh Apexi SAFC where do I get that for $150 ? LOL More like $300.
Remember I'm a penny pincher.
Dude, there are 2 in the classifieds on this site, and at least 3 i saw the other day ended on ebay for around $150. You just need to look. They are out there.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
