jesse12345
- 1,269
- 1,122
- Jul 30, 2014
Minnesota
I've got a very weird idle surge even when I first start the car in my 70 degree garage. I have ECMLink on speed density and no FIAV just running an IAC. When the car us fully warm it idles rock solid and everything checks out great.
I've checked up and down for leaks and I have zero. This issue came about after I added the IAC because before I had everything blocked off and it idled very good. Is this something I'm just going to have to live with?
I have everything just about as stock in ECMLink as I can make it. My whole setup is stock aside from 550cc injectors and 5 bar map sensor. I don't see how adding the IAC to the throttle body would make it worse so I'm a little confused. I can post a log if it helps.
I'm stupid and didn't post this in the right section so if one of the mods could that would be great. That was my bad.
Here is a cold to hot idle log.
