keith2g
- 40
- 0
- Mar 21, 2011
feasterville,
Pennsylvania
Wondering if anyone out there has experimented with this setup and if so, what type of results were achieved. Im currently running an MHI 20g that I purchased from Forced Performance in a BEP tdo5 bolt on and have been pretty pleased with the results.
The car recently went 11.7 @ 125mph with a 1.9 60ft on pump and meth (full weight). I plan to push this turbo to its limits and I'm looking at different alternatives to how I can do so. The turbo is in need of a rebuild so im currently pulling it but while I have it off of the car I plan to swap on a bigger compressor wheel and housing. The wheel is a 25g (60.2mm inducer 78mm exducer) and the compressor housing is an anti-surge 3" inlet. Im also sending the turbine wheel to gpopshop to have it clipped 15* (I know how some of you feel about clipping a wheel so please hold the negatives). The end result will be a clipped tdo5 anti-surge 25g in a BEP bolt on. Kinda sounds like a mutt but just curious as to how others might predict the performance of this setup. Any input will be greatly appreciated.
I planned to try and run 27-29 psi on my 20g next season on the new build.. I hope I dont have this luck..
