awdmonster1904
Freelancer
- 856
- 558
- Aug 23, 2007
Chino,
California
What stater would I need for auto swap 1g with a 2g trans
Thank you
Thank you
Yea currently using the Kiggly kit but it’s going on a 1g chassis.Are you using the Kiggly kit? I am also having starter issues. I have tried the auto and manual and it seems like the gear to the starter doesn't go out far enough. I'm hoping to learn something as well. I am using a 6bolt in my 2g.
To provide good input, I would like to think to use a 2g starter since your using a 2g trans and converter. I attached pictures regarding the difference between a 2g auto vs manual starter. I hope I dont cause confusing here.
| Starters | |
| Swap | Starter |
| 1G AT in 1G Car | 1G MT or AT starter |
| 2G AT in 2G Car | 2G AT Starter ONLY |
| 2G AT in 1G Car | 2G AT Starter ONLY |
Update ***
I ended up using a 2g starter for a 5 speed car however i added washers as thick as the starter plate the washers are between the bell housing and starter.
I hope this helps anyone doing a swap.
