Resolved 1G OEM relay pinout
need2boostpsi
557
6
May 9, 2005
Mountain home, Arkansas
quick and easy question, when looking at a oem 4-pin relay from a 1g, from the bottom with the clip down what pins go where? I using a stock relay to rig up something and my multimeter is being a beast. A picture would help as I'm slow to catch on. Also while serching I found servile threads on aftermarket relays. which had a pinout based on numbers but I don't believe there are any on the stock relays.
the relay in reference is the one for the stock fog light I want to use it for my second fuel pump.
Typing the question cost you more of your time than buying a Bosch relay would have. However, with four terminals, you should have one that powers the coil and another to ground it, leaving the other two as the make/break contacts.
Post a picture.
I have used a few OEM relays for other projects. The 12v and GND are usually diagonal from each other. You will have to get a 12v source and test the relay by connecting 12v and GND while listening for a click. If its NOT the two pins I marked then try the other two.
12v and GND can be reversed on the pins and it wont matter. For example you could put the GND on the pin I marked 12v and 12v on the pin marked GND. It wont matter either way, the relay will still function.
alright i got it wired up had to flip the ground and the fuel pump wire but other than that it works fine for my inline pump.
