1G Starter relay
goonie
251
4
Mar 2, 2004
soutomaior/spain, Europe
Hi there
Look at the pic and tell me if this is the starter relay (Please)
Put in a new starter but it doesnt turn Just clicks
When i turn the key and hold my fingeren on the relay i can feel it clicking how do i take the relay out?
thanks
That's probably the starter relay. You could also have an issue with the ignition switch and clutch switch.
clutch switch is dissabeld
i found a you tube video from a 91 dsm with the starter relay part number MB510818
when googeling that part number i get a starterrelay for a 2G?
the pics in my earlier posts from the relay seems to be the abs relay
is there a way to test my ignition switch or do i have to replace it?
thanks
Manual or Automatic?
IIRC, the manual trans uses a NC switch that disconnects the starter signal from the started when activated by the clutch safety switch grounding the starter relay coil and the automatic uses a NO switch that makes the circuit when the trans inhibitor switch is in park.
So if it's a manual and you feel the relay clicking, something is telling it to break the connection of the starter.
It's a manual.
The relay i thought was the starter relay was actually the abs relay (the one who was clicking), the starter relay has the part number MB510818 on it.
I think my problem is a bad ignition switch. When I turn the key I only hear a click every now and then. When i wiggle the key it clicks and cranks sometimes.
I think a bad connection in the switch gonna replace it.
I got a part number for the switch MB542442 or MB606048
Do you happen to know which one?
thnx
